When i move files to another folder it doesn’t work. thx
It's the right click menu.
Please explain in detail exactly what you are trying to do, and how you are doing it. Assume I cannot see your computer and know nothing about it, or how you are operating it, so leave out no details and I’ll attempt to recreate this condition to confirm if it’s a bug, or you are asking it to do something that violates your computer’s settings.
Hi,
I get the same error on v1.65.
Recreation steps:-
1. Select multiple completed files
2. Right click and select 'File Move' to a location.
3. Nothing happens
i also can get the issue, but what I have learned is changing the properties. Because it has happened often an entire file is just wiped.
I have found that changing it in the properties menu is fairly solid. The program seems to have some trouble with conducting multi-file operations, using update trackers doesn't seem to work across 10 files, i've not really tried with only 2-3 running.. etc
