Hello, so first with the general info:
What version of BitComet are you using? 1.19
What type of Internet connection do you have (ADSL, etc.)? cable 12 Mbit/s
Do you have a modem? Do you use a router? What make and model are each one of them? Have you forwarded your port? **I got Thomson TG784 router, i tried to forward the listen ports. Did it in accordance with the guide that was posted here on forums. **
If you have more than one router, be sure to mention the make and model of both devices, how are they connected (i.e. in which connector of both devices is the network cable plugged) and which one of the devices is connected to or is the modem.
Also, if you have more than one computer make sure to mention in this case, to which router is every one of them connected.
I got only one router. It is connected via cable to my PC. Another laptop is connected to this router via wireless. Also perhaps it is necessary to mention that the router transmits to digibox for one TV set, but we rarely you it.
- What version of Windows, Firewall and Antivirus do you use? Vista, Windows Firewall, and Avast Antivirus
Ok so the problem is as stated in the topic: in Bitcomet it says that Listen port of TCP is blocked by Firewall/router, but at the same time Listen port of UDP is open. Then below it says “Windows firewall: Added [TCP opened, UDP opened]”, and “UPnP NAT port mapping: Added”.
I get the yellow light with text “WAN IP address + listen port are blocked”.
To say honestly i haven’t been tinkering with assigning a static IP, since in *ipconfig/all * under Ethernet adapter Local Area Connection there is a line “NetBIOS over Tcpip: Enabled”, but then under Tunnel adapter Local Area Connection there is a line “NetBIOS over Tcpip: Dissabled”. I’m all confused here.
Any suggestions ?
Thanks for helping in advance.
